1 - 18 of 18 Posts
I need to find someone near manatee county Florida to tune my zx3. Just had a turbo kit installed and need to get the fuel to keep up with boost. I have called at least 6 places near me with dynos but none will touch it. Either they only work on Japanese or European. And the ones that do domestic only do dodge or chevy. I got really screwed over by the mechanic who installed the kit and ended up having to redo the whole system. I'm not very knowledgeable on turbo systems other than changing out parts so the fact that I went back and fixed it mostly impressed me. I have an sct tuner that kinda helps but not all the way. So any place within about 50 miles of manatee county that will do it, I will go check out.
#turbonewbie
Try asking your neighbors and if they have solid recommendations otherwise your best bet would be to travel to the nearest county, maybe try posting on craigslist/FB's local community section
Discussion Starter · #3 ·
That's who I have been asking. And customers, and other performance techs. Nobody knows anyone who can or will touch it. I guess I will have to wait a while till I can purchase a full tuning kit with the ability to remap everything. I have permission to use a dyno at a local shop but they do not have the ability to tune. Only dodge and chevy. If I take the wastegate apart, I only want to pull out 1 spring. I like the boost I am able to maintain but with the controller turned all the way down, I'm getting too much still. I'm not entirely sure how the wastegate works so I want to make sure I remove the right part to help my situation. But as it sits, 0-70 in 4 sec at least, if not less. I am trying to find gas pedal equality between boost pressure and fuel flow. So far I can hold a good 5-6psi without fuel cut out. I know I have a long way to go and it's going to get expensive, but I started it, so I have to finish it. I would like to start an only focus meet. If I can get permission from my boss, I would have it at the shop. Hopefully soon, I can get that going.
I
maybe, how would that work?
You hook up the XCal and datalog, send the file to the tuner, they review and update your calibration, mail it back to you, you flash. The cycle continues until they're happy with the car. You'll need a safe place to do 3rd gear pulls. You'll also need a wideband installed and connected to the XCal.
It's a good option, especially when there's no one locally who can tune the car on a dyno.
Discussion Starter · #8 ·
Ok. Since I don't have o2 sensors installed, would that work out? Or should I drill and install? I'm good on the mechanical side. Just not on the electronic and technical side. Still learning all this stuff.
I
I would find a tuner first and see what they recommend. They'll likely have a "favorite" or recommended wideband o2 to install. I like the AEM, but usually best to follow the tuner's guidance on what they like.
Another thing, could I hook to PC and have them update it online?
They'll email you the tune and you hook the SCT up to the computer and save the file to it. Is that what you mean? Unfortunately you can't hook a PC directly to the car and have someone remotely flash it.
Discussion Starter · #11 ·
That would be awesome. But you did answer my question. I'm just looking for someone that does it. That will take some time to go through resellers on the website and find one to send me a tune. I have emailed steeda already and hope they tell me yay or nay. Emailed another a little closer to me too. Fingers crossed.
Discussion Starter · #12 ·
I need a clutch to hold up to at least 500hp. Any suggestions?
I feel your pain on the tuning problem. Went the same route with turbo. The original local tuner who wasn't interested.
Why do you need a clutch for 500hp? Sounds like you may be in over your head for a novice.
Discussion Starter · #15 ·
The clutch slips under 5psi boost. The clutch is stock and brand new. And if I get to a point where I can run full boost, it will be running 500hp. Right now, it's fine. Pulled out wastegate spring, pulled vacuum, and learned gas pedal position so I don't overlook and cut out my fuel till I can afford to get it completed.
Thats a monster build to make 500hp to the gound.(y)
Mine makes 240 to the ground w/10psi. and a stockish Luk Gold. Luckily my car never stops as it is road racer.
Discussion Starter · #17 ·
Yeah, I totally didn't expect what I have going on with this little car. Never messed with boost in my life and always wanted to. The mechanic that installed it really screwed me over on price and workmanship. But having to go back and fix his many many mistakes, I have learned more than I expected to. But I have also lately been thinking of switching up to supercharger since it's a little easier to manage and it's not sitting on the exhaust. Still all stock too. Only turbo system is installed. No fuel management, no ignition, not even tuned. I have a handheld tuner but I only does so much. Will keep updated.
1 - 18 of 18 Posts
