'06 and up suspension kits (Ford Racing)
4.5K views 39 replies 17 participants last post by  JEEPers
I just got my first shipment of the new Ford Racing suspension parts for the 2006 and up Focus.
It's supposed to give about a 1 1/2 inch drop on the ZX3, ZX4 and ZX5 (still no wagon parts)
Part numbers,
Springs M-5560-ZX3B $170.50
Shock/strut kit M-18000-ZX3B $159.50 this kit includes mounting hardware.
I can be reached at 1-800-328-9552 ask for Steve.
what are the spring rates for those springs?
funkdaddyfresh said:
^~~ x2. Also, has anyone seen this combo. i got burnt on springs once and had an uneven drop. So are these good for an even drop.
These are made by ford, they arent chinese ebay junk
Okay, I have an '07 ST and this is one of the first things I want to do.
If I just get the springs, will my other components wear prematurely? Or should I get the whole kit? Coilovers would of been great, but still none available for the '06+ focus's.
Thanks
Thanks
Generally you are better off gettting the whole works since it's all designed to work together.
From what others have said, using drop springs on stock shocks/struts can shorten their life but there is no way to tell for sure.
i know this has been asked before and the answers alwasy diff, will i NEED an alignment? and what about shipping to 14006?
OmniFocus said:
Yes, you will.
Altering ride height will alter toe, which will wear the tires rapidly as well as tweak the handling toward the negative. Camber is affected as well, but will likely be tolerable.
Besides the fact that it's not always real easy to get everything put back in exactly the same place as when it was taken apart.
Even if you think you got it right it's not a bad idea to at least get the alignment checked.
i was under the impression that the only diff was the sway bars. i know the svt had a slightly lower stance but though the others where the same.
focus00zetec said:
I'm still a little confused about these Shocks/Struts...
Are they any different than ST shocks/struts or is this Ford selling ST shocks/struts as a kit???????
And I've heard that the ST suspension has slightly shorter springs stock.
So if that is true, how much would these springs drop an ST even though its a ZX4?
I have sold a few sets but I have not seen them on a car yet.
I hope they drop the car lower than the stock ST parts, the stock ST stuff is plenty high.
I'm fairly sure it'll be a decent drop even for an ST model.
just ordered mine today, ill have some pics in about a week when i get it and get it on. :thumbup:
Agreed, ur wheels need more meat. with those tires your car still looks way high, that settles my debate on what tire size im going with.
IDK why but ur front still looks high to me?
well remember that the rear is higher to begin with so lowering the rear more is ok. from the looks id say the front springs either arnt seeting right or theres a problem with the spings. could be the springs settling but i would have thought that the rears would have been higher in that case do to less wieght. guess we'll have to wait and see.
Edit: looking at the pics again the front looked high to begin with.
