Originally posted by TRUenemy00:
does anyone have a decent How-To on it?....
<font size="2" face="Verdana, Arial">Sure, this if from the 2002 Service Manual CD:
Removal
</font><ul type="square">[*]<font size="2" face="Verdana, Arial">Drain the cooling system. For additional information, refer to Cooling system Draining, Filling and Bleeding.</font>[*]<font size="2" face="Verdana, Arial">Disconnect the coolant hoses and detach the thermostat housing.
</font>[*]<font size="2" face="Verdana, Arial">Remove the thermostat.
</font>[*]<font size="2" face="Verdana, Arial">Remove and discard the O-ring seals.
</font>[/list]<font size="2" face="Verdana, Arial">
Installation
NOTE: Install new O-ring seals.
NOTE: Install a new thermostat.
NOTE: Make sure to locate the new thermostat into the thermostat housing.
</font><ul type="square">[*]<font size="2" face="Verdana, Arial">Install the thermostat.
</font>[*]<font size="2" face="Verdana, Arial">Install the thermostat housing and reconnect the coolant hoses.
</font>[*]<font size="2" face="Verdana, Arial">Fill the cooling system. For additional information, refer to Cooling system Draining, Filling and Bleeding.</font>[/list]<font size="2" face="Verdana, Arial">
