16"s would be better for gearing, rotational mass, cost of tires, etc. 15"s would be even better.
Bear in mind that some of this requires removal of some of your current components.i would like the list of stuff for the stock pathway
I agree with that. Wanna really do it on the cheap, go with 14"'s and run Azenias 196/60-14--$50 each shipped16"s would be better for gearing, rotational mass, cost of tires, etc. 15"s would be even better.![]()
Yep.so wait if i take off my t/b and stick to me plan of falken azenis tires and new shocks/springs i can compete in STS?
I'll echo this, except w/ the S2, I don't think you'll necessarily need the bigger rear bar.Yep.so wait if i take off my t/b and stick to me plan of falken azenis tires and new shocks/springs i can compete in STS?
Alot of people say the bet 'kit' is the Apex. I chose a bit stiffer spring in the Intrax-SVT and matched those to SPAX dampers--adjustable in the rear (so far).Konis are the hot setup if you have the cash.![]()
A big key to getting the car to turn is to get some camber up front--camber adjusters should be a high priority, IMO. Then, at the least get a 22/22.5mm rear bar--or bigger if you are careful regarding the LCA issue (see posting on adjustable rear bar for more...)
