okay guys, I did the 2.5 swap on my 06 zx4 st and its up and running. sometimes it runs PERFECTLY fine but other times its giving me a hesitation issue.... it typically starts in first gear taking off from a stop. I'll push the gas and let out of the clutch and it will engage the gear but it is SUPER slow to accelerate, then its almost like it suddenly gets the signal and accelerates hard.
Almost like the clutch was slipping and it didnt engage but the clutch is functioning properly (as the rpms are not reving up when this occurs.)
there seems to be no rhyme or reason to when or if it happens. almost all the sensors on the motor are brand new, cam, crank, tmap, temp sensor, fuel pressure sensor, tps....
kinda at a loss.... thoughts? ideas?
