okay guys.... just did my 2.5 swap into my 2006 zx4 st.
I used a 2014 fusion engine for the swap, using the 2.3 valve cover, oil pan and dipstick tube, and timing cover. (also used all the 2.3 accessories, alternator, ac, power steering etc) Im using the 2.5 block, head and intake manifold. (with an adapter plate for the 2.3 throttle body)
Engine starts and runs but idles a bit rough and stumbles upon acceleration... that being said I am using the 2.3 fuel rail (w pressure sensor) because I figured that would assure the computer would react normally. however after everything was installed I realized that the 2.5 intake does not have the access port to feed that sensor with the vacuum pressure that it needs. (which surely is why its acting the way it is at the moment) any ideas on bypassing this or where i should try to tap into the system to gain the vacuum necessary ?
any ideas, or help would be greatly appreciated.
