1 - 1 of 1 Posts
I need Help!
I have a 2001 zx3 2.0 DOHC ATX, that had a burnt harness. Wanted to go to manual, so found a 2002 zts 2.0 DOHC and swapped everything except the wiring harness under the dash.
Now the OBD port is not registering the ECU, and the instrument cluster isn't registering and i need help. is there a way to make this work without swapping that dash harness, or what are my options? (Note, found pin 91, going to nothing at the connector at the base of b pillar. This is a return ?)
1 - 1 of 1 Posts
