Some basic items that I perform to my car.. overkill style.
Fuel filter every 30k.
Transaxle flush every 30k.
Yearly brake fluid flush/bleed.
Regular brake pad examination.
Coolant flush every 30k.
Check for leaks routinely, particularly the valve cover gasket on an older Zetecs.
Probably more items, but those are what I keep an eye on.
I also change out suspension bushings as I see fit.
Your owner's manual in your glovebox has a list of recommended services at recommended intervals. Not a bad idea to follow those.
Personally I'd avoid the dealership for anything, but you may not have the mechanical skills to do it all yourself. A regular service shop may also be a better deal.
Oh yes, and: Welcome to the Jet.
