1 - 2 of 2 Posts
I'm working on my rear trailing arm bushings, I've got to the point of trying to get the bolt out?? I got the nut off, but the bolt is givin me prob's!??!! Any ideas????
I
Are these the bolts into the upper/lower control arms? If so, the bushing sleeves are probably seized to the bolt and you need to cut the bolts out. Those arms will need to be replaced too.
I suggest getting all new hardware from Ford when you do the rear. The new stuff has MUCH better corrosion coatings (what they use on new cars).
1 - 2 of 2 Posts
