1 - 4 of 4 Posts
Hey what’s up guys new to the forum but I used to own a svt zx5. I replaced the engine on my wife’s 2010 focus and I’m at the point where I have to tighten the axle nuts but the spin and when I try an out the transmission in park from the manual selector lever it doesn’t seem to work any advise ideas would be appreciated thanks in advance
I
Tighten them down as much as you can, and then tighten like you do lug nuts - Pop out the center cap in the wheel and lower the car down a bit onto the tire to hold the hub from turning. Torque to spec.
Or, place a breaker bar or pry bar through the wheel studs, brace against the ground, and tighten.
Discussion Starter · #3 ·
Thank you so much do you know what position the manual selector goes to for park
1 - 4 of 4 Posts
