1 - 3 of 3 Posts
2012 SE hatchback: My horn stopped working, which means that the alarm doesn't work either. I checked the fuse, but it's ok. I heard somewhere that the horn volume might be adjustable - true? If so, how? If not, what else could be going on?
Quite a few have had issues with the connection to the horn, and a number with the horn itself.
Listen for a relay clicking, if you can hear that a problem AT the horn is more likely.
Having neither alarm or wheel button working also points toward the horn rather than to a horn button/wheel cable problem that has also been seen.
Thanks for replying. Would I hear the relay clicking in the car or outside? 'Hitting' the horn yields only the sound of my hand on the vinyl. Pushing the red button on the key is soundless, but after about the 4th time, my 4-way flashers came on (I had to start the car to get them to stop).
1 - 3 of 3 Posts
