225 Width tires on stock SVT 7\" Rims?
I am looking to get a set of 225R45/17 tires for autoX next year. The stock size on the car is 215R45/17, if I go to 225 will I get rubbing on the strut?
I searched around and most people seem to be questioning if they can run 7.5" rims I am wanting to keep the rims I have on the car, just mount 225 meats onto them.
Re: 225 Width tires on stock SVT 7\" Rims?
hmm I'll just wait till Falken releases the 215R45/17 Version of the new RT-615
if you can use 205/40/17 on the svt rims, then you can get em now, and looks like the rt-615 is available. this will also make the tire diameter less and should improve acceleration over stock size. it will be lower profile than stock
IF you want em get em!!! I had 225/45-17 Kumho MXs on my car for a while with the drop of my H&R coilovers, which at full height is lower than most street "drop" springs that are out there and I only rubbed if i had people riding in teh back or hit a bump while cornering relatively hard. If I could have afforded the extra $50 i would have gone back to the 225s. I guess its a personal choice as to whether or not you can put up with a rub here or a rub there. The place where my rubbed was at the back of the wheel well, where the front facsia meets the front door/rest of car.
CCC
I tried the 205/40/17 and I'm not a huge fan. There just isn't enough sidewall and it's much easier to bend a rim on the street.
The 225/45/17 is much wider and has a lot more grip. You can do the stock svt rim like me, but I'd prefer a lightweight 7.5" rim. You will more than likely need to roll your fender lip.
