325HP and 331TQ
1.4K views 29 replies 20 participants last post by  CCC
At the wheels and still on the ALL stock SVT engine even the TB
We will try to push it to about 350ish very soon and will try to test our stage 3 sheet metal intake the next time on the dyno
Tom
god thats alot of power
That sr20det swap you did, it's really paying off!
So...whats under the hood of that thing then??? Under what boost did it pull those #s?? That thing is awesome...hopefully I'll be able to post #s like that in my sig!!!
CCC
CCC,,So...whats under the hood of that thing then???
*Its all 100% stock under the hood other than my turbo kit and the 3 Inch Exh , No cam gears , No TB
*That was with about 18PSI
Tom
331 tq is really damn high. Doesnt really even sound like a zetec power curve what was the problem with torque in the upper part of the tach? Why is there such a good midrange and such a restriction up on top. Wierd dyno numbers but damn good job.
Stage.. i hate that word more then anything else
STAGE 5 TURBO! WHEWW!!. God i could kill someone everytime i hear that.
hey tom, i know you like keeping your turbo specs to yourself
but can you at least tell me what kind of turbine and compressor housing youre running? And when does it make full boost?
Ok i said stage 3 because it is the 3rd make on the intake the first 2 with fitment issues and flow i didnt like what it was doing on the flow bench once we got them to fit so i did some changes and like what this 3rd build is doing
Oct was 105 and on 93 it makes about 230 to 240 but every one allready knows im a high Oct junkie
Tom
I am to far from home to go with out a trailer when anything could happen from a wheel bearing to an engine going ,Who knows what could happen
If it makes it 2 days on the track the way i beat on them it would of made it there and back
Tom
Tom, Your 3in. exh, Is that a cat-back? Would you make the same numbers with a borla 2 1/2 in??
I just like to say AWESOME!!
I would really like to see what kind of numbers it puts down with the intake manifold on it and a ported head and some cams....that'd be well into the 400s eh?
