I wanted to add an oil pressure gauge to my dashboard beside the instrument cluster but I am really quite crap when it comes to fiberglassing, painting, finishing, etc. Fortunately for me a couple of us in my office banded together to buy a low end 3D printer for fiddling around with and it seemed like just the right tool for the job.
Here are some progress pics, I'll try to expand this writeup when I have a bit more time.
First - a test ring to see if I modeled the contour right. It is effectively some splines wrapped across the surface of a ~1.5m radius sphere.
A quick mock-up of where I wanted the gauge to sit and filling in the main plate of the gauge pod
Some cutting is required. The lower section was removed by cutting the plastic welds, then a minute or so with a dremel to cut out a hole for the gauge to rest in
A quick render of the finished gauge pod.
Up until now I've been printing the parts with whatever colour of plastic we had the most of (ugh, buttercream) with thick layers. Right now I'm running the part shown in the final rendered image with super thin layers to get a better surface finish. There are 10 hours remaining in the print job but if it turns out well tomorrow I'll have some finished pictures of the pod mounted up with the gauge installed.
