1 - 11 of 11 Posts
www.focus-central.com
Got mine there with the flex-pipe for 415$
Great gains with my head package and should give you 4-7 hp with just bolt-ons
Inebriated Pecker Obstructionist
ZXTuner.com is finishing their 4-2-1. Pricing is supposed to be $350.00, and that includes the o2 cheater.
Link
FocusSport is close to finishing and releasing theirs... should be around very shortly.
tony d at newedgeperformance.com got my fc one cheaper than from fc. give em a try.
g
I believe the 4-1 will sacrifice a bit of low end torque for high end horepower, where the 4-2-1 is the opposite, it will most likely lose a bit of high end power for some low end torque.
I believe that's correct.
Try this link. It lists the engine configuration for that test at the bottom. http://www.steedafocus.com/charts/charts10_3.htm
If you want to see more of our test results go to www.steedafocus.com and click on TECH & INFO. Look for the articles titles "Focus Buildup"
Since those tests we've added the Ford Racing Head, Intake, and bigger cams. Look for those results to be posted soon.
1 - 11 of 11 Posts
