1 - 8 of 8 Posts
I'm running H&R race springs and Konis, dropping me about 2" (maybe more). I would like to pick up some 16" Rota Grid's, but they are a 40mm offset. What tire size do I have to run to not rub?
you're most likely going to rub with that offset and drop. 205/45/16, 205/50/16. wouldnt' go any bigger than that.
i run tsw revos (40mm) 17x7 with 215.40.17's dropped with a H&R cup kit, rolled the inside lip of the fender and no more rubbage
I had 17x7, 215/45/17 with a progress tech drop and rubbed. Going with the 16" rim if they are 7" wide and maybe a 205/40/16 you might get by, but it will be close. I am not familiar with the h&r kit.
i would not suggest running a 205/40/16. not enough meat to protect the wheel. i bent 2 wheels running that size tire. do a search for OUCH!!!!!! and you'll see what im talking about.
yeah, I would prefer 45 series as well. But I figure the 40 would help a bit since he is lowered. Yes it is more risky for damaging the rims. I have 18's with 35 series though and haven't had any problems. next time I will spend the extra for 40 series just for better piece of mind.
H&R cup kit is 2.5F/2.75R
also i have hit some serious ridges and what not in this [censored] hole state or arkansas and never had a prob with 40 series
1 - 8 of 8 Posts
