just wanna say i love what BMW start doing with their engines cant wait for the V8 M4.
Not that interesting. BMW is changing their naming scheme, so the M4 will actually just be an M3 sedan.They have a M4 in the works? Interesting...
It is only a little 5.0 liter......and its "only" making about 325lb/ft. of torque up near redline. Peak torque is still below 400. The high redline is impressive, but its really not that powerful of an engine.
correctIt is only a little 5.0 liter......and its "only" making about 325lb/ft. of torque up near redline. Peak torque is still below 400. The high redline is impressive, but its really not that powerful of an engine.![]()
Dont get caught up in the amount of cylinders. For example, the Dodge Viper with a V10 is putting out 500 HP and 500+ ft/lbs of torque but it's using 1.8 liters more displacement to get there (Vipers V10 = 6.8 liters). Where the BMW is using a 5.0 liter V10. So yes more cylinders but smaller, with shorter stroke to allow the high RPM's. So they are doing a heck of alot more with less. Much like a formula 1 car. The Forumula One engines are also 10 cylinders (currently) but are only 3.0 liters which is why they need to rev to 19K RPM's to get their mega High HP numbers....and its "only" making about 325lb/ft. of torque up near redline. Peak torque is still below 400. The high redline is impressive, but its really not that powerful of an engine.
Even worse, it is an 8.3L! Of course, low-end torque is fantastic with that sort of displacement.....(Vipers V10 = 6.8 liters).
Not really, like I just said the M4 will be the coupe/convertible and the M3 sedan. BMW was hesitant to just drop such an icon completely. Here's the website for the M3 spy shots from the 'ring. The E90 is sooo sexy.Not that interesting. BMW is changing their naming scheme, so the M4 will actually just be an M3 sedan.They have a M4 in the works? Interesting...
Don't get caught up in looking at displacement either (and its much bigger than that... hot-rodded truck engine).Dont get caught up in the amount of cylinders. For example, the Dodge Viper with a V10 is putting out 500 HP and 500+ ft/lbs of torque but it's using 1.8 liters more displacement to get there (Vipers V10 = 6.8 liters).
Its not really that impressive. A high rev engine is ok, mated to an auto tranny or standard in a heavy sports sedan, while its still pretty fast, its not the best idea.It's making 100hp a liter.
How is that not impressive?
All a matter of opinion though I guess. I am impressed.
That's purely speculation.I also think that you really won't get even close to those numbers on the dyno. For some reason something tells me that the engine won't last that long at such high rpm's. That's a lot of valvetrain to push around, time will tell.
-bix
Yes it is, but it is informed speculation. I'd be happy to find a M5 and dyno it on my own dollar. I'm also a mechanical engineer and I've seen lots and lots of "high" powered high rev machines completely choke on the dyno. Great hp number, not so great torque number and then combined with a heavy weight(3800+lbs), not so great....That's purely speculation.
perfectly put.Dont get caught up in the amount of cylinders. For example, the Dodge Viper with a V10 is putting out 500 HP and 500+ ft/lbs of torque but it's using 1.8 liters more displacement to get there (Vipers V10 = 6.8 liters). Where the BMW is using a 5.0 liter V10. So yes more cylinders but smaller, with shorter stroke to allow the high RPM's. So they are doing a heck of alot more with less. Much like a formula 1 car. The Forumula One engines are also 10 cylinders (currently) but are only 3.0 liters which is why they need to rev to 19K RPM's to get their mega High HP numbers....and its "only" making about 325lb/ft. of torque up near redline. Peak torque is still below 400. The high redline is impressive, but its really not that powerful of an engine.
Dont be fooled, this car might not have the tire shredding torque that some might want (though 380 ft/lbs is nothing to smurk at). However it's is going to plant you in your seat as those RPM's climb!! I can't wait to hear one!
So if it performs "poorly" on a dyno, and then puts down advertised numbers in real world performace, does it really matter what the dyno has to say?Again, powerful engine, but I'd REALLY like to see what the power curve looks like on a dyno. Good luck
-bix
The old low compression 5.0L 302 put down 300 fb-ft of torque at around 2000rpm with the wimpy cam it had. I've seen with a cam change and a good computer tune a engine put down almost 320lb-ft at the tires! I will say the best 302 hp I've ever seen NA is 370ish at the tires. Which puts it about 420 engine hp at a 6000rpm redline. Still about 80 hp short. But the torque was about 370 also which is thumping for a small bore, low rpm 302.A Viper is hard to drive on the limit? M5 is not? That would be my guess.. Also that 7 speed SMG transmission with the microsecond shifts keeping it in the powerband probably doesn't hurt.![]()
And sure the M5 isn't a torque monster, what do you expect with a 5 liter V10 that revs to 8200 rpm? Compared to other 5 liter engines it makes more than enough torque, and way more hp. But to say it's not impressive is just crazy talk. The V10 weighs less than the old V8 from what I understand as well.
