1 - 5 of 5 Posts
Sir Buffs A LOT
Decided to give the ol' paint your calipers a try today. Decided on using Krylon Black BBQ spray paint. Had used it previously on my rear drums and they are holding up well. Also picked up some Duplicolor High Heat Aluminum colored spray paint to do the clip on the brake pad & the lip of the rotors. Well here are some pics and lmk what you all think;
That looks awesome, and ST200s look much nicer up close like that.
Sir Buffs A LOT
Discussion Starter #4
Looks great Mark!
So, did you just scuff them and go to town?
Thanks Hale. I took the calipers completety off. Sprayed the crap out of them with brake cleaner and used a old toothbrush for the nooks and crannys. Dried them off real well then took the Dremel to them real quick with a brush attachment. Taped off the needed areas and sprayed them. Nicked up the frot a little trying to get that spring back in place. You can see it a little on one of the pics. Just came back in after a little touch up to that area. Sprayed some paint on piece of cardboard, took a small brush and covered that area.
1 - 5 of 5 Posts
