1 - 9 of 9 Posts
Tarderatoraka: Red-SE-00'
I want to have faith in Focus Central sometimes...but I just cant bring myself to it.
4-2-1 vs. 4-1
So if the problem with the 4-2-1 is that the pipes on cylinders 3 and 4 need to be interchanged. Wouldnt this be the same affect as if it were a 4-1 header? Essentially it would all be going into one collector. Or am I looking at this all wrong??
dunnoo.....discuss.
Plz stay away from bashing FC.
Gabe
"The firing order of the engine is 1,3,4,2. This means to evenly space the flow out every other cylinder needs to be joined. In other words, #1 should be joined with #4 and #2 joined with #3. This allows the secondary pipes to receive alternating pulses and doesn't exhaust two consecutive firing cylinders together."
Hmmm, that is a good question. Maybe it's that they are all firing parallel with each other in a 4-1 exhaust?, and not into each other like 4-2-1...
the reason 4-1 and 4-2-1 aren't the same I think has to do with the amount of scavenging that is going on at once and how soon the opposing cylinder is scavenged.
For example : In a 4-1, it just goes by the firing order.
#1 exhaust pulse passes the collector and then #3 gets scavenged by the #1 exhaust pulse, then #4 by #3.
In a 4-2-1, #1 scavenges #3 and #4 individually. By the time the number 1# pulse gets close to the last collector to suck out the #3 pulse that is coming up right behind it in the other set of pipes it has also been scavenging the #4 pulse, then when #1 passes the collector, it sucks out #3's pulse which then also sucks out the #4 pulse and so on and so on. So it ]is different since the #4 pulse gets acted on earlier in the 4-2-1 design. Which would explain why a 4-2-1 header makes more power earlier but not as much peak as a 4-1.
I dunno, that's how I think it works.
Discussion Starter · #4 ·
I see I see!!
I wonder if we could just get a shop to take some pre-orders and do up a few REAL race headers for us SPIs!!
I may look into this.
I see I see!!
The problem is spi'ers in general like bang for the buck and don't like paying out the ass for stuff. Custom 4-2-1 headers will cost a ALOT.
Discussion Starter · #7 ·
yeah...this I know....
But what are the benefits of a 4-1 header??
It will all be the same on the bottle to me!!
haha
1 - 9 of 9 Posts
