Naz...I've noticed we think very much alike with these cars, only I've also noticed your wallet is a lot deeper than mine, but the turbo solution is here my friend... it lies in the rods, cams, and pistons from race engineering in florida i believe makes the car 2.3l and 8.5:1 with the right grind for boost, an F-Max turbo kit, a recalibrated MAF and injectors, and an apexi boost controller and fuel controller... That settles that once and for all I believe... then we move onto the transmission where you may or may not want a lightweight flywheel, I personally would, even if it does make the car impossible to launch, it makes it rev faster than you can imagine when it is not in gear, also get a quiafe, some different fluid, and a contour SVT final drive gear. now to continue the traction solution, the fenders need to be rolled, pulled or simply redone to accomidate a minimum tire size of 235/40/17 for serious boost. put all of these things together, and you would have what I wish my wallet would permit me to do, I believe you already have the cup kit like me, as well as front and rear stress bars... how about sway bars? anyway the above is what my logic has lead me to believe is the ultimate setup, one badass looking widebody high boost zx3...
