1 - 4 of 4 Posts
Ok, this is what I have so far. I was going to take the car in for inspection but just recently (figures it always happens around that time) my wiring has come loose on my SVT seats in my non-SVT ZX5.
I am going to paste some info I have from a wiring diagram.
Code:
For the Driver seat:
svt pin 1: driver side-airbag signal: wire to driver seat harness pin 9
svt pin 2: driver side-airbag return: wire to driver seat harness pin 10
svt pin 3: not used
svt pin 4: not used
svt pin 5: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 6: heated seats switched power: wire to driver seat harness pin 5 (green and red wire)
svt pin 7: seatbelt buckle sensor signal: wire to driver seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to driver seat harness pin 4
svt pin 9: powered seat-height power: wire to constant power
svt pin 10: powered seat-height ground: wire to ground
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 5
svt pin 12: seat heaters ground: wire to passenger seat harness pin 8
svt pin 13: seat track position sensor signal: wire to driver seat harness pin 1
svt pin 14: seat track position sensor return: wire to driver seat harness pin 2
For the Passenger seat:
svt pin 1: passenger side-airbag signal: wire to passenger seat harness pin 9
svt pin 2: passenger side-airbag return: wire to passenger seat harness pin 10
svt pin 3: seatbelt pretensioner switched power: wire to passenger
seat harness pin 5
svt pin 4: seatbelt pretensioner signal return: wire to passenger seat
harness pin 6
svt pin 5: heated seats switched power: wire to passenger seat harness pin 1 (green and blue wire)
svt pin 6: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 7: seatbelt buckle sensor signal: wire to passenger seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to passenger seat harness pin 4
svt pin 9: not used
svt pin 10: not used
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 6 (red and orange wire to accy power)
svt pin 12: heated seats ground: wire to passenger seat harness pin 8(to black wires on switches)
svt pin 13: not used
svt pin 14: not used
And this is a diagram of the seat connectors.
Problem I have is I took my wires out of my connectors on the "Square Connector" image above so I no longer know which wires of what numbers. It seems to be stemming from my passenger seat. There are 2 yellow wires, one with a thick brown strip and one with a thin black stripe. The other 2 are green with and orange stripe and a black with a red. I need to know what numbers those 4 wires are off of the normal "Square Connector" so I can fix my problem.
I need to get this done pretty quickly. I am going to Tampa on sunday and would like to get it done before then.
If anything I hope this post will help anyone with seat wiring problems at the same time. I have noticed there really isnt a guide for this since these 2 items I have posted have never been found in the same post for some reason.
Well, since no one wanted to take a picture I had to go to Ford and get a wiring diagram.
This is what the driver side looked like before I took the wires off.
hey man just to recap with you. Did you ever get your Recaro seats to be fully functional? I have the same connectors I believe. Do you have a picture of how you wired them? Long shot here. I know.
1 - 4 of 4 Posts
