1 - 3 of 3 Posts
I can't find any info on these, but I found a set of AEM swaybars that were supposedly ade by Eibach for a little while. seller says they have the same measurements as the Eibach set (22mm and 25mm). Anybody know about this?
Well I don't know about the rear bar, but I can tell that the front bar that I bought of someone did not fit well at all, I had to uninstall it and tossed in the garbage. It was not even close to the same shape as the Eibach front bar and it hit the subframe over every bump. Piece if crap. I wouldn't waste your time with the front bar, but like I say I don't know about the rear.
The AEM sway bars are early Eibach bars. They should fit fine although you may have to devise a 'fix' to keep the front bar from moving around. If you get a good deal on them I say buy them.
A Front bar is definitely worth while installing on a Focus. Be prepared to spend a few hours under you car to get it in there. After you do it once you'll see it's really not that hard.
1 - 3 of 3 Posts
