1 - 7 of 7 Posts
Does anybody know the total length and diameter of the tubing in the AEM CAI? If you know the volume of the tube that'd be great, but the length of tube an diameter would do nicely. Thank you.
diameter is 2.5"
Isn't it a little smaller? Because it's the same size as the stock MAFS whatever that is... Pretty sure it's metric though...
Another thing to take into consideration if you need an exact volume is how the metal is bent. If the pipe is not mandrel bent, then you're going to lose volume in the pipe curves. Not much, but if you need something exact, that might be a varible to consider.
I'm not sure whether or not the AEM is or not because I don't have one and have never seen it posted. I would assume it is because of the company, but I could be wrong. Just something to ponder I guess.
Discussion Starter · #7 ·
I'm trying to figure that out. I want to do the math to see how it affects the theoretical length of the intake runner as was suggested by The focus builder's book.
1 - 7 of 7 Posts
