<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>
I'm sure this has been asked...probably too many times.
What effects will a ported head and different cams have on the AC3? I'm assuming it will give it a tendency to overspool quicker. <hr></blockquote>
Without claiming to be to much of an expert on the AC or turbo's in general, I'm thinking a port/polish of the head might not be a good thing. Here's why and I'm sure some of the more techy guys here can correct me if needed: (and I'm sure they will)
A P/P'd head is going to flow more air than a stock head unit requiring your turbo to flow more air to achieve the same amount of boost. It's going to make your turbo work harder to achieve similar results. And you might end up seeing less "peak" performance gains.
The over-spooling I think could only be a major danger at high RPM's but I doubt it will be an issue.
So if I got an ACIII with a few other general mods, would a new clutch be necesary, or would the stock one hold okay?<hr></blockquote>
Would you
need a new clutch? Probably not.. but would it be a good idea to actually be able to put that power to the wheels without slippage??? I think yes.. I personally think it would be a not so good idea to boost power while ignoring your driveline. But heck.. what do I know
[ 03-02-2002: Message edited by: belacyrf ]</p>
