After CAI install, car feels slower
5.1K views 7 replies 4 participants last post by  me_etc
I have a 2000 Focus ZX3 automatic. I installed a Bombz Cold Air Intake, with the filter it came with, and managed to drop .105 off my 1/8 mile time the same day of the install (time is now 10.656). I notice a very slight gain at and above 4500 rpm, but off the line the car seems slower than before (I had the stock airbox and a K&N drop in filter). Any ideas why a CAI would feel slower off the line than the stock air box? How would I counteract this? I need to lower my 60' as much as possible, and while the gains above 4500 help, the slow starts don't.
If it means anything, I'm changing the fuel filter tomarrow in the hopes it is the problem. I have 49k miles, and the fuel filter has never been changed.
_________________
[ 04-02-2003, 02:27 PM: Message edited by: jRock ]
i think the AEM dyno's have show that the style of that intake sorta tends to cause a trade off between low end and high end power. that's why you could be feeling the slight loss. or maybe you've got a bit of a leak some where in the intake (doubt it...but always a possibility)
i bought a cold air intake of of ebay. I dont think it was bomz but it is gray and probablly prety much the same thing. I changed out the filter with a k&n and it mad a notisible diff. Mabey try that and see if it helps.
I could be totally wrong on this, so maybe some of the gurus can confirm/deny this. I read somewhere, though, that because it is an aluminum pipe, it will transfer more heat than the plastic stock tube did. Therefore, once the engine is warm and idling, your engine is intaking very little air, and the air in the aluminum pipe will have heated and expanded more than it would have in the stock intake. Hot expanded air is what you're trying to avoid in the first place. The proposed solution was to insulate the pipe with heat wrap of some sort. As described, this is horrible for aesthetic reasons, but wonderful for hp reasons.
While I see your point Wedge, when you're at idle, you're intaking very little air. Don't you think the air in the intake is stagnant (motionless) and sits there and heats up? Wouldn't this account for the dyno's of the CAI's showing low end loss?
