1 - 5 of 5 Posts
When i start my engine the lights on my instrument panel and my headlights seem to flicker a bit for a few seconds.. is this an indication my alternator is going bad? I have about 22,000 miles on the car. If i install the afx udp, will this make the flickering worse? Will the udp dim all of my lights?
[ 10-31-2002, 04:06 PM: Message edited by: chris_k ]
are you saying you're starting the car with the lights on and thats when they flicker? if so, derr. the starter is a big drain on the battery.
i think i wasn't clear. if that is happening when starting the car only and you have your lights on while you start your car, that is (while not necessarily NORMAL) its okay to happen. and a UDP will not change anything, because at that time, electric accessories are running off the battery
1 - 5 of 5 Posts
