1 - 7 of 7 Posts
Just an FYI, the cylinder type air filter from a dodge stratus 2.7 will fit the 3" (or whatever it is) tubing on a marcy, but there's not the clearance to get it to stick on the tube securely, i believe the FS is the same size tube but since it curves up, you should be able to mount it.
just an fyi for those like me that hate K&Ns and want a paper filter that still flows more than the engine needs...
and the sound is the same. I ran one on my marcy the last week and it didn't fall off but i'd be weary running it without the bend like the FS kit.
I have wonderous butt cheeks
You mean clearance like the filter is too long for the opening?
well you can't slip it onto the tube far enough...at least not for me to be comfortable not to use a clamp because there's no lip to clamp on to. on the FS design, you could just slip it over and the tension would work with gravity to hold it on.
What's wrong with K&N filters that you would perfer the paper element filter... Do the k&n flow much less? require cleaning more often?
a K&N won't be replaced nearly as often but it uses an oil to catch dirt in a gauze filter. the oil slips through and you have to clean your MAF sensor when it gets covered in the crap the K&N lets through.
I've seen the flow numbers on K&N compared to other filters and the real issue (especially for us) is the boxes/piping, not the filter itself. actually just dropping a K&N in will add maybe 1hp on a bigger motor.
I pulled my K&N off the other day after replacing it about 4 months ago...after cleaning it twice before in 30k (50k my ass). yesterday I put my stock airbox back on after seeing all the crap that the brand new K&N let through in 4 months. there shouldn't be a layer of dirt and oil that thick on my intake tube after the filter...i'm sorry, but that kind of [censored] in a motor will fubar your rings and cylinder walls and I'm going to stick with the stock airbox until I rebuild the motor and then I'm glassing a custom box for a real big paper filter (the one for a hemi comes to mind). either that or i may buy an ITG filter but i'm still weary.
Discussion Starter #7
no it was on a brand new filter...twice. granted when i oiled it id did it too but that doesn't bother me as much as the clean filter with the layer of dirt inside the tube.
1 - 7 of 7 Posts
