Manual trans $127.17 plus a $75.00 core.Starter for a 02 zx3
Shipped to San Diego
You know what? I didn't have the compressor in the last list, for some reason I thought you already had a new one lined up.thanks. And what about just the compressor and a belt?
Also, do you stock the tool that is used for changing the timing belt?
The SVT Contour was a 2.5 V6, that's not the sensor you want.could you verify that the SVT countour "2000 model" is a 3/8 NPT thread and that it has the same connector as the focus I went to the parts house and there is 3 different connector types... I know one was wrong because it was round but the other 2 look just like the focus SVT but they both look its a little different from each other...
Im trying to get the Bostig Thermo housing installed...
and I will need a qoute
Contour SVT coolant temp sensor
Focus SVT Thermostat housing gasket
Focus SVT 192 F Thermostat
Thermostat gasket
why not on the sensor? is the one you are offering me a 3/8 NPT?The SVT Contour was a 2.5 V6, that's not the sensor you want.
The next issue is that we don't know for sure which housing to head o-ring the Bostig housing was designed for, there are two different ones Ford used.
Sensor $22.54, I have to assume this one will work, it's the one we sell in the Contour conversion for the SVT
Housing to head o-ring $3.85 or $5.23
Stat $8.54
Stat o-ring $4.40
I saved the list on quote Q519206.
-Steve
I added the plugs to the quote, I don't have any official spec on the sensor size but my highly accurate plastic ruler says it's about 3/8"why not on the sensor? is the one you are offering me a 3/8 NPT?
Housing to head gasket the squared off oring like stock... didn't know there was 2 different kinds..maybe ill have to get both.
also add 8 plugs for the SVT focus... coppers work
Looks like NPT to me, the sensor is off a late 90s 2.0 Contour.haha Thanks man ...& is it NPT thread pitch? What is this sensor off of normally that you're getting me? ill call you tomorrow or Monday to get this stuff ordered, you rock Steve!
What's the VIN? There were multiple intakes used.How much for a standard Zetec intake manifold with all the hoses on the back?
If it's the square solenoid (should be) I have it in stock $94.96 plus shipping.I need a shift interlock solenoid for my mom's 2002 Escort. I've looked everywhere. I really don't think their available, but giving it a try here.
Here is a pic. Disregard the red writing, it's not mine. The cylinder/plunger has a black box on the side of it. Is that what I would need ?If it's the square solenoid (should be) I have it in stock $94.96 plus shipping.
-Steve
The sensor number you have is an engineering number for an older sensor, not the one I sell for the stat housing conversion.hey Steve on that coolant temp sensor,is it ford part number F5AF-12A648-AA?
and are the SP487 coppers just a colder copper specific to the SVT instead of the SP463?
