Car died in the middle of the road, battery light was blinking before that.
Car can start with battery charged up/ a jump, but will not charge (multimeter shows voltage drop, so not charging)
Checked that the Alternator case had continuity with the battery negative terminal.
Fuse 10 checked.
Can't test the hot wire continuity since I can't remove the connector, (maybe I will have take the Alternator down first?)
Questions:
1. Where is Alternator Fusible Link? Does being able to start on battery but not charging say anything?
2. What is the purpose of the 2 connector in red and purple? I don't see the red connector been connected (I might be blind, or it was at a bad angle).
Fuse 10 checked.
Questions:
