1 - 3 of 3 Posts
If you have an electric aftermaket tach, and pulg into ecu #48 does that cut the stock tach off? Could you make only the aftermarket tach work? Problem is I have a gtech pro rr, and since the needle stops at 7,250 or so, and I rev to 7,800 rpm the shift lights, and some other readings are off on the gtech because it calibrates itself to the tach.
I installed mine on #48, the stocker still works, don't know about turning off tho
, if the g ready calibrates on the tach, where does it conect too?
It plugs into the The cigerate lighter. I lowered the shift lights to 7,250 from 7,650 and it works fine. Maybe my calibration is off.
1 - 3 of 3 Posts
