I have just replaced my timing belt tensioner and idler on a Zetec. My question is has anyone observed the movement of the belt tensioner (single idler setup) while the car is running? I have tensioned the belt with the cams loose etc. following the shop manual with the timing tools etc.. I rotated the motor over twice and checked the marks and tensioner. When the car is running the tensioner moves quite a bit and the tensioner does not return to the mark at rest?
I have a spare motor on a stand with 60k and when I manually rotate the crank the tensioner stays on the mark and doesn't hardly bounce? Anyone have a similar experience?
