1 - 3 of 3 Posts
Looking for a copy w/ any diagrams. Anybody have access to this? Alldata does not have it yet...
Yeah i cant find it on my normal sites either
You mean this one?
FORD: 2002-2004 Focus
ISSUE:
Some 2002-2004 Focus SVT vehicles may exhibit a broken or cracked catalytic converter mounting bracket.
ACTION:
Replace the catalytic converter mounting bracket.
SERVICE PROCEDURE
Remove two (2) M8x16 bolts from engine side of catalytic converter mounting bracket (Figure 1).
Remove two (2) M8x25 bolts from catalytic converter side of catalytic converter mounting bracket (Figure 1).
NOTE: DO NOT REMOVE THE "ENGINE" BRACKET.
Remove catalytic converter mounting bracket.
Install new catalytic converter mounting bracket.
NOTE: IT IS CRITICAL THAT THE BOLTS AT THE CATALYTIC CONVERTER SIDE OF THE MOUNTING BRACKET ARE TORQUED FIRST. FAILURE TO DO THIS MAY RESULT IN BRACKET FAILURE.
Install two (2) M8x25 bolts at catalytic converter side of catalytic converter mounting bracket. Torque the bolts to 168-186 lb-in (19-21 N-m).
Install two (2) M8x16 bolts at the engine side of catalytic converter mounting bracket. Torque bolts to 168-186 lb-in (19-21 N-m).
Figure 1 - Article 05-14-12
PART NUMBER PART NAME
4M5Z-5A204-A Catalyst Bracket
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
OPERATION DESCRIPTION TIME
051412A 2002-2004 Focus SVT: Replace Catalytic Converter Mounting Bracket 0.3 Hr.
DEALER CODING
BASIC PART NO. CONDITION CODE
5A204 01
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2005 Ford Motor Company
1 - 3 of 3 Posts
