<font size="2" face="Verdana, Arial">I totally forgot about H22 (Prelude engine)Originally posted by 1FST2M6:
http://www.placeracing.com/
i've been involved in H22 to ZC swaps for nearly 10 years... Place makes the easiest kits.. and zdyne or hondata to controll the new engine.
<font size="2" face="Verdana, Arial">Sorry... had it reversed... my bad. But yes.... that is what I was referring to.Originally posted by hatched:
What BUR_ZX3 is referring to is what is commonly called and LS/VTEC (B18B block w/B16A or B18C head) or the CR-VTEC which is the B20 block with the B16A or B18C head.
<font size="2" face="Verdana, Arial">no offense or anything, but apparently you dont know everything there is to know about honda engines. there is no welding involved with doing an h22 swap into an eg civic. the only modification to the mounts is that you have to cut part of the tranny mount off of the car to avoid it from hitting when first gear is engaged. also, you have to cut a notch in the radiator fan to clear the clutch bleeder valve, unless you buy an aftermarket fan that is thinner. the shift linkage is in a slightly different location, so you have to cut a larger hole where the old shift linkage came through. these are the only modifications to the actual car that i can think of off the top of my head. i just helped do this swap within the last month, and it was actually pretty straightforward.Originally posted by ukcuhp:
dont do the h22, not a cool swap, its to big to fit well and mounts need to be cut and welded and its just a pain in the ass, i know from personal experience. PM me if you have any specific questions or need more help, i know pretty much everything there is to know about honda engines.
<font size="2" face="Verdana, Arial">I've heard of LS or B20 blocks with B-series heads, but never a LS/B20 (they're both non-VTEC).Originally posted by BUR_ZX3:
You could always get a "frankenstein" and drop that bad boy in.
LS engine with a B20 head.
<font size="2" face="Verdana, Arial">**looks out to garage, sees 92 si with h22a**Originally posted by everyone-needs-a-clear-focus:
no offense or anything, but apparently you dont know everything there is to know about honda engines. there is no welding involved with doing an h22 swap into an eg civic. the only modification to the mounts is that you have to cut part of the tranny mount off of the car to avoid it from hitting when first gear is engaged. also, you have to cut a notch in the radiator fan to clear the clutch bleeder valve, unless you buy an aftermarket fan that is thinner. the shift linkage is in a slightly different location, so you have to cut a larger hole where the old shift linkage came through. these are the only modifications to the actual car that i can think of off the top of my head. i just helped do this swap within the last month, and it was actually pretty straightforward.[/QB]![]()
<font size="2" face="Verdana, Arial">The D1Z6 is just an older version of the D16Y8. The Y8 has a better intake maifold, too. The Y8 was in the 1996-’00 EX, the Z6 was in ’92-95’ EX and Si. It was less horsepower and torque, and ran OBDI, too (but is better for using a Hondata ECU). Both engines are SOHC VTEC.Originally posted by everyone-needs-a-clear-focus:
as hatched mentioned, if you currently have a d series motor, swappin a new one in wouldn't be a bad idea. personally, i wouldn't go for the d16y8, as i prefer the d16z6. much funner engine from my personal experiences.
