#2 I would expect but I believe #1 would only be the case if using the AFC like normal. Has anyone with a Focus used an AFC in "Hack" mode???1. The Ford ECU will adapt to it and trim things back to stock, thus it won't do anything.
2. If you make large changes you'll go places in the timing map that you don't want to be.
