1 - 4 of 4 Posts
Are the TSB\'s the same?
Okay, I go to a Ford dealership and they printed me off a list of the TSB's after they typed in my VIN. Well, I went to another dealership and gave them the same printed copy of the TSB, because my engine mount is bad, well they tell me that there are different TSB's for the regular Focus's and SVT's. So they didnt fix my engine mount. Is that right????
Re: Are the TSB\'s the same?
Matt since your VIN would indicate that you have an SVTF it should apply to your specific vehicle so they should have taken care of it.If you can,post the TSB numbers that are on the print out that they gave you along with the explaination for what it is for so someone can look them over here for more input.
**Edit**
I just noticed that you have an 02 so the TSB which is not a recall so you could be out of warranty by now.
i got an ESP, good for another 7k
Having ESP isn't a guarantee you can have TSB's done for free.
TSB's often have a coverage limitation -- usually within basic warranty. That means that you'd only be covered for a repair if the TSB addresses your problem and you're still under bumper-to-bumper warranty.
1 - 4 of 4 Posts
