1 - 8 of 8 Posts
hey guys, in a couple months i am going to drop my ride, put some 18's on and a 25mm sway bar.
what should i do to the engine just to increase reliability?
only power mods i want to do at this point is an exhaust.
you guys are going to laugh but right now i am running the stock exhaust. cut off right before the muffler. actually sounds pretty good. and adds a couple of horses. definite noticable increase. but anyways. little bit of a budget build. what should i do? just a good top end build? valves, seats, valvetrain, i.e. springs, retainers etc?
oh and by the way. H20boy. your tranny gone yet? hehehe. need to go whoosh again. hehe
bryan
That all sounds pretty cool, but if you are a budget guy, save the cash you'd spend on the 18's and get nice tires for some stock rims.
Don't Call Me Gaga!
18's will make extremely poor autocross wheels.
As for the rest of it, don't just buy mods for an "auto-x" build... you'll end up in a class that you can't possibly be competitive in.
Pick a class and don't mod beyond those rules.. something like STS.
bryan
Get a long tube header, mbrb exaust ($199 www.mbrp.com), and CAI for engine mods. Leave the valve train alone for now, you will want to learn how to properly drive your car on the track first.
Get a good suspension, Spax makes an adjustable kit which is roughly $400ish www.batinc.net
Get a good euathane kit for your suspension since your going to be doing that anyways.
H&R makes a good rear sway, I'd recomend starting out with just the rear sway at first then upgrade the front after a full season of auto-xing.
Also stay far far away from anything bigger than 16's get soem 16's with smaller, grippier rubber. look at some Faulken Enzie's (sp?) or Kuhmo 712's.
- Josh
well. im not going for stock rims. i want the widest rims i can go at least. I have an lx with 14" steelies.. screw stock rims. i may find some good svt rims and do it that way. but im also kind of going for a certain look. im just wondering what is the problem with 18's? would they slide alot? ill get the suspenion answered in suspension. i just basically want the reliability down. ill have about 6-7k to drop down if everything goes right.and i am already pretty good at driving my car. have never hit a single cone to date. i just have problems with nav through the cones. but once i get that down. its on!
That's alot of rotational mass, really. You get into gearing ratios when you change rim size, and honestly, I don't know squat about it. I'd recommend going into the Auto-X forum and ask about rim size there.
Something that big (even if they are "lightweight") is going to detract from your straight-line speed, too.
I agree with you guys, to a point. I run OZ Superleggera 17's with Kumho Ecsta Supras. The weight is a shade less, and the diameter is the same as my stock 15's. So my speedo stays the same, gearing is the same, all that. I didn't do it on purpose, it just happened that way.
And for the life of me I can't kill the transmission. 65k of thrashing and it just keeps coming back for more.
1 - 8 of 8 Posts
