1 - 11 of 11 Posts
What is the least amount of fuel that can be run w/o getting into starvation issues...who has tried what successfully? I've been a full tanker...
Depends on the condition of your fuel pump I guess. I used to be able to run down to/past the fuel light being on. Now, I get starvation at just above the 1/4 tank mark. But only in high speed sweepers on a track. Will find out next weekend how it does at an auto-x but I'll probably be a "full tanker" as well just for safety's sake.
I've run it with less than 1/8 of a tank (light came on) with no problems, and I've run on a full tank. I kinda like to run right at or just under 1/4 tank. I think my focus can handle a little fuel sloshing around better than it can handle the weight of a full tank. Gas is heavy... Remember, our car is too heavy to begin with.
Discussion Starter #4
Gas is heavy...
Yep...that was my whole point of seeing who has done what...if we all can take the weight of 8 or 9 (or more) gallons out of the back of the car with no ill effects, it would seem to make sense to do so.
I'd like to see how the car scales (crossweight) with a full tank. Of course, those with t3h coil-overs can adjust for this, but for those who do not have spring height adjustability, this would be an interesting bit O' info.
The tank's position is a good one for balancing out the driver, and our in-tank pumps like to be cooled by fuel.
Yes, our cars are already too heavy and I know where the engine is placed... just pondering here, that's all...
Last Sunday, we ran under 1/4 tank down to maybe an 1/8th. I think the fuel light came on on my last run. No problems. Then drove 15 miles or so to the next gas station after the event.
Van
At one Autocross I shared my car. We ended up running without any issues with the needle below the empty mark.
But, I wouldn't put too much faith in the fuel gauge on my car relating to the fuel level on a different car. Does that make sense?
Discussion Starter #8
You mean I can't use your fuel guage to see how much gas is in my car? Shucks!
Don't Call Me Gaga!
I run well under 1/4 tank as well... except when my pumps were failing and I was forced to run 3/4 tank to keep from starving.
Now I know you know that is NOT what I meant!
I usually have to drive a ways so I usually end up racing with about 1/4 of a tank. But this past weekend I did most of my runs (before cording my tires) with the light on, which for my car is consistently around 2.5-2.8 gallons (ran out of gas once). Even a quater of a tank is about 2.5gal OVER the reserve so a quarter of a tank is like 5gal+
I think theres a HUGE difference between and 1/8th or 1/4 versus all 13gal. I think there was a post somewhere that mentioned something about a gallon of gassoline weighing in around 6lbs...78lbs over the rear with a full tank.
CCC
1 - 11 of 11 Posts
