If they are the standard 2.5" spring size then custom rate springs come in 25lb increments, cost of mine were $60 for some Hypercoils. I can't tell you what the H&R's are like but I'm very happy with my Leda's.
I am aware that you can order stiffer rears from H&R, but am unsure of the cost.So my question is two fold...any of you AutoX H&R guys, is my friend right...and can you order stiffer rates from H&R, and how much would those springs cost?
CCC
I didn't know it was so neutral. I was planning on the H&R rear sway regardless of suspension setup. Thanks for the info...it makes sense and I think I'll head in that direction if I can.I am aware that you can order stiffer rears from H&R, but am unsure of the cost.So my question is two fold...any of you AutoX H&R guys, is my friend right...and can you order stiffer rates from H&R, and how much would those springs cost?
CCC
You're friend is right in that more rear roll stiffness will tend to make the car rotate easier and quicker, but it's noteworthy that with the H&Rs the front end works so well that the car is very neutral and pointable as is. One of the benefits of the H&Rs moderate rear spring rate beyond decent ride quality, is the fact that the rear is very settled and predictable- something difficult to keep as spring rates climb.
A very effective tunable option for even more rotation is changing rear roll stiffness with rear swaybar size instead of spring rate. The H&R's with the 24mm rearbar is a great, responsive set-up for auto-x, while still being very streetable and not the least bit twitchy.
H&R swaybars
Isn't that the European style? I remember when the H&Rs first came out in the US, they were full Euro-spec and had taller rear springs. Then they started coming with shorter rear springs so that the adjustment range was more in line with what us wacky US people wanted. I got the taller rear springs initially, but later got the shorter ones as well. I'm pretty sure they're the same rates, but I'm not 100% sure. If anybody local had a "spring dyno" type thing I could find out.I run custom valved and lower rear H&R. The problem that I had was that the rear was too tall compared to the front. ...
Read my auto-x thoughts in the H&R Swaybars thread in FocusSport's forum.How do you guys like the coilovers for autoX...hows the handling vs stock? Turn in? Neutrality? Oversteer?
CCC
CCC
It was too much rake. Now the rake is less and the car looks more balance and "tucked" the way it should. Before it looked like a 77 Camaro with rear leaf shackles. The rear Shocks are ok for the new springs but If I went lower in the rear the shocks would have to replaced. As for the valving they are set up for the Nurburgring 24 hours DTM. I might be changing them for another setup, MIGHT BE.Isn't that the European style? I remember when the H&Rs first came out in the US, they were full Euro-spec and had taller rear springs. Then they started coming with shorter rear springs so that the adjustment range was more in line with what us wacky US people wanted. I got the taller rear springs initially, but later got the shorter ones as well. I'm pretty sure they're the same rates, but I'm not 100% sure. If anybody local had a "spring dyno" type thing I could find out.I run custom valved and lower rear H&R. The problem that I had was that the rear was too tall compared to the front. ...![]()
I don't know if H&R ever changed the rear shocks. I don't recall ever hearing of anyone getting new rear shocks in addition to their shorter springs.
