1 - 8 of 8 Posts
I got everything I need to put battery in hatch, I was just curious as best thing to do with stock power and ground cables. It looks like the stock ground has a couple wires coming off of it that are needed, and the power cable has two wires attached to battery, figured I'd see what some of you do to hook it up properly.
our ground from the battery is attached to the cage, in front to the chassis, the hots up front are ganged together and connect to the 0 guage wire that goes back to the battery
What you use to gang them hots togther, like a fatty power distribution block or something?
just a block on the metal brace above the right hand motor mount
you will like working on the car much more with that anchor out of there
Re: Battery relocation question, best way to hook up power cabel
Just make sure that you do not have anything that can come into contact with the distribution block up front.
Discussion Starter #8
I am going to coat it with the red stuff, so it should be all good.
1 - 8 of 8 Posts
