1 - 5 of 5 Posts
i just need to know how to completely disconnect the battery from my car...i am just gonna have it undone for like 20 minutes. people said it was reset my ECU and thats exactly what i need it to do? help please!
just disconnect the negetive termanal
take of the (-) batt cable (NOT THE RED ONE) and pull it completely away from the post. Use a 10MM socket to losen the bolt. It won't come off. Its tight so it will be a little difficult. Thats all you need to do to reset the ECU. Leave that off... turn on your headlights and insert the key and turn to the ON position to drain all the juice hidden in various capacitors and you'll be all set after a few minutes.
all you need to do is take the battery cover off. un-screw the screw on the negative battery terminal and lift the connector off the terminal post...
leave it off for 15 minutes, put it back on.
start the car, let it idle for 10 minutes. turn the ac on and let it idle for another 5-10. then take it out for a ride...
1 - 5 of 5 Posts
