1 - 10 of 10 Posts
I currently bought a Zetec from a 2001 Focus with the plans of transplanting into my 89 Escort. The problem I have is I got the engine, wiring harnes and computer out of an auto tranny car as opposed to a manual tranny car. The major questions I have for all of you is A) Does anyone have an ECU from a manual ZX3 they would be willing to trade, or sell B) Does anyone have, or know where I can find online a pin out chart or diagram of Either ECU C) Does any one have or know where I can find online a whiring diagram for the Focus. Thanks alot for any help anyone can give me.
Hey man good luck on your hard work ahead. Regfarding looking for the parts i would either check on the classified or look on one of those part locators websites. Best of luck!
Thanks for the luck. I have been looking around for the parts, but it is the information that I really need right now. I ordered one of those shop manual CD's from someone online. They say it is a copy of the original Ford shop manual CD. Hopefuly that will have the info I need on it. But if anyone knows somewhere else I can get the info I need online please speak up.
That would be a Great help Racer. I need all the info I can get and the best place to get it in my mind is straight from the horses mouth. I have the EVTM and factory shop manual for my escort because I don't think Chilton and Haynes do all that great especially when it comes to wiring diagrams.
2001 PCED OBDII SECTION 6: Reference Values
2.0L 4V Focus (A/T)
Typical Diagnostic Reference Values
Sensors/Inputs PCM Pin/PID only Measured/PID Values Units Measured/PID
KOEO Hot Idle 30 MPH 55 MPH
TRR/TR 4 VBAT/REV (N) VBAT/REV (N) .1/OD .1/OD DCV/MODE
TRL/TR 7 VBAT/MAN1 (N) VBAT/MAN1 (N) .1/OD .1/OD DCV MODE
TRD/TR 8 VBAT/DRIVE (N) VBAT/DRIVE (N) .1/OD .1/OD DCV/MODE
TROD/TR 11 VBAT/OD (N) VBAT/OD (N) VBAT/OD VBAT/OD DCV/MODE
FEPS 13 .5-.6 .5-.6 .5-.6 .5-.6 DCV
CKP (+) 21 0 400-425 900-1000 1200-1400 Hz
TCS 29 .1/OFF VBAT/ON (G) .1/OFF .1/OFF DCV/OFF-ON
PSP V/PSP 31 .1/LOW VBAT/HI (I) .1/LOW .1/LOW DCV/LOW-HIGH
TSS 34 0 340-380/
680-720 620-680/
1160-1180 1090-1150/
2150-2220 Hz/RPM
O2S12 35 .1 (D) (D) (D) DCV
TFT 37 .5-2/210-110 .5-2/210-110 .5-2/210-110 .5-2/210-110 DCV/DEG
CHT V/CHT 38 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 .67 or 3.7/194 DCV/DEG
IAT 39 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) 1.7-3.5/120-50 (K) DCV/DEG
FPM 40 3.5/100 3.5/100 3.5/100 3.5/100 DCV/%
ACCS 41 .1/OFF VBAT/ON (A) .1/OFF .1/OFF DCV/OFF-ON
EPCSW 44 VBAT VBAT VBAT VBAT DCV
PATSIN 53 (T) (T) (T) (T) (T)
OSS 58 0 0 67/400 120/730 Hz/RPM
GFS 59 0 130/30 130/27 130/23 Hz/%
O2S11 60 0 switching (C) switching (C) switching (C) DCV
FTP V/FTP 62 2.6/0 2.6/0 2.6/0 2.6/0 DCV/IN-H20
FRP V/FRP 63 3/43 2.8/39 2.8/39 2.8/39 DCV/PSI
CPP/PNP 64 VBAT/ON VBAT/ON 5/OFF 5/OFF DCV/OFF-ON
DPFEGR 65 .95-1.05 .95-1.05 .95-4.65 .95-4.65 DCV
KS 57 0 0 0 0 DCV
CID 85 0 5-7 11-15 17-21 Hz
ACP 86 VBAT/OPEN VBAT/OPEN VBAT/OPEN VBAT/OPEN DCV/OPEN-
CLOSED
MAF V 88 0 .6-.9 1-1.6 1.3-2.3 DCV
TP V 89 .53-1.27 .53-1.27 1-1.3 1.1-1.9 DCV
BPP 92 .1/OFF VBAT/ON (E) .1/OFF .1/OFF DCV/OFF-ON
ECT PID .4-1/200-160 .4-1/200-160 .4-1/200-160 .4-1/200-160 DCV/DEG
EFTA PID 50-120 (K) 50-120 (K) 50-120 (K) 50-120 (K) DEG
FLI PID 50 50 50 50 %
GEAR PID 1 1 4 4 GEAR
LOAD PID (L) 10-20 20-31 25-52 %
MISF PID OFF OFF OFF OFF OFF-ON
OCTADJS PID NO RETARD NO RETARD NO RETARD NO RETARD RETARD/NO RETARD
RPM PID 0 730-790 1450-1630 1750-2100 RPM
VSS PID 0 0 30 55 MPH
Actuators/ Outputs PCM Pin/PID only Measured/PID Values Units Measured/PID
SS2 1 .1/OFF . 1/OFF . 1/OFF .1/OFF DCV/OFF-ON
MIL 2 .1/OFF VBAT/OFF VBAT/OFF VBAT/OFF DCV/OFF-ON
HFC 17 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON
PATSOUT 19 (T) (T) (T) (T) (T)
INJ3 20 0 3.3-3.7 4.1-8 4.4-10.1 mS
CDA 26 VBAT VBAT VBAT VBAT DCV
PATSTRT 27 (T) (T) (T) (T) (T)
VSO 28 0 0 65 125 Hz
PATSIL 42 (T) (T) (T) (T) (T)
EGRVR 47 VBAT/0 VBAT/0 11.5-VBAT/ 0-40 10-VBAT/0-60 DCV/%
CTO 48 0 25-38 40-48 72-85 Hz
CDB 52 VBAT VBAT VBAT VBAT DCV
EVAPPDC 56 0 0-10/0-100 0-10/0-100 0-10/0-100 Hz/%
FP 54 3.7/75 1.5/33 1.5/33 1.5/33 DCV/%
EVAPCV 67 0 0-10/0-100 0-10/0-100 0-10/0-100 Hz/%
LFC 68 .1/OFF VBAT/ON (B) .1/OFF .1/OFF DCV/OFF-ON
WAC 69 VBAT/OFF .1/ON (A) VBAT/OFF VBAT/OFF DCV/OFF-ON
SS1 73 .1/OFF .1/OFF VBAT/ON VBAT/ON DCV/OFF-ON
INJ1 70 0 3.3-3.7 4.1-8 4.4-10.1 mS
GENFDC 72 0 0 0 0 Hz/%
EPC 81 0 9.3/57 9.0/68 9.4/86 DCV/PSI
DPC1 82 0 0 3.93 4.10 DCV
IAC 83 VBAT/0 9-10/20-40 8-11.1/34-40 6-7/45-55 DCV/%
HTR11 93 .1/ON (P) switching switching switching DCV/OFF-ON
INJ4 95 0 3.3-3.7 4.1-8 4.4-10.1 mS
INJ2 96 0 3.3-3.7 4.1-8 4.4-10.1 mS
HTR12 100 .2/ON (P) .2/ON .2/ON .2/ON DCV/OFF-ON
DPC3 102 0 0 0 0 DCV
DPC2 99 0 0 0 0 DCV
CHTIL PID OFF OFF OFF OFF OFF-ON
FUELPW1 PID (L) 3.3-3.7 4.1-8 4.4-10.1 mS
LONGFT1 PID (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 (-)20-(+)20 %
SHRTFT1 PID (L) (-)10-(+)10 (-)10-(+)10 (-)10-(+)10 %
TCIL PID OFF OFF OFF OFF OFF-ON
SPARKADV PID 0 15-22 28-35 25-35 DEG
Other PCM Pin/PID only Measured/PID Values Units Measured/PID
VPWR 71 VBAT VBAT VBAT VBAT DCV
VREF 90 5 5 5 5 DCV
NOTE: All generic OBD II readings under no load (PARK or NEUTRAL).
GENERIC OBD II PID VALUES PID Hot Idle 2500 RPM Units
LONGFT1 (-)20-(+)20 (-)-20(+)20 %
LOAD 32-38 16-20 %
MAF 2.4-2.7 7.2-8 G/S
SHRTFT1 (-)10-(+)10 (-)10-(+)10 %
SHRTFT11 (-)10-(+)10 (-)10-(+)10 %
SHRTFT12 95-100 95-100 %
SPARKADV 15-22 25-32 DEG
Discussion Starter #9
Thanks for the info Racer, I will try to make some sense out of it. It seems to have gotten jumbled a bit in the post. If you could send me the Manual tranny info too that would be great.
2.0L 4V Focus (M/T)
CKP (+) 21 0 400-425 900-1000 1150-1400 Hz
PSP V/PSP 31 .1/LOW VBAT/HIGH (I) .1/LOW .1/LOW DCV/LOW-HIGH
KS 57 0 0 0 0 DCV
OSS 58 0 0 200-220/
430-450 360-827 Hz/RPM
FRPV/FRP 63 3/43 2.8/39 2.8/39 2.8/39 DCV/PSI
CPP/PNP 64 5/OFF .1/ON (J) 5/OFF 5/OFF DCV/OFF-ON
CID 85 0 5-7 11-15 16-21 Hz
CLOSED
ECT PID 160-200 160-200 160-200 160-200 DEG
RPM PID 0 700-750 1630-1820 2100-2400 RPM
CTO 48 0 25-38 48-59 72-85 Hz
CDB 52 VBAT VBAT VBAT VBAT DCV/%
FP 54 3.7/75 1.3-26 1.5/27 1.5/30 DCV/%
EVAPC V 67 0 0-10/0-100 0-10/0-100 0-10/0-100 DVC/OFF-ON
LFC 68 VBAT/OFF .1/ON (B) VBAT/OFF VBAT/OFF DCV/OFF-ON
IAC 83 VBAT/0 9-11/20-40 8-11.1/34-50 6-7.5/45-60 DCV/%
HTR11 93 .1/ON (P) .1/ON .1/ON .1/ON DCV/OFF-ON
SPARKADV PID 0 15-33 28-35 25-35 DEG
VREF 90 5 5 5 5 DCV
Note: All generic OBD II readings under no load (PARK or NEUTRAL).
LONGFT1 (-)20-(+)20 (-)20-(+)20 %
LOAD 38-48 16-20 %
MAF 1.6-2.6 7.2-8 G/S
SPARKADV 15-33 35-38 DEG
1 - 10 of 10 Posts
