Actually, the part called a sliding contact went away when the airbag came out. It is now called a clockspring. Second, if the problem is Your blinker keeps flashing when it should've cancelled, then the clockspring will need to be replaced because the plastic piece that hits the cancelling lever on the flasher switch is broken, but if the blinkers just stay falshing even after the switch has cancelled, You have other issues.
