I'm getting together parts and information to turbo my distribitorless car, one of the last things on my list is a ignition system to retard timing to prevent detination. I would prefer one that can retard with boost instead of a fixed retard amount. So far this is what I found, I will be greatfull for any info you can supply. I did a search but came up with way too much stuff thats not really related.
MSD
$319.95 MSD-6211 DIS 2 This can set to retard timing at RPM levals. (above 4,000 RPM)
MSD
$419.99 + 69.99 MSD-6212 DIS 2 The additional MAP sensor ($69.99) can be used to retard timing with boost, this is better but its $489.98
CraneCams
6000-6500 HI-6DI2 Ignition $313.99
9000-0110 MAP sensor for boost retard $57.00
6000-6425 Adjustable under dash knob $117.00
6000-8933 Electronic trigger $137.00
Total $624.99
http://www.cranecams.com/CraneCams.htm
Did I miss any? Keep in mind I dont have a ton of money.
Thank you
MSD
MSD
CraneCams
Total $624.99
Thank you
