<font size="2" face="Verdana, Arial">mess w/the screw? dont mess w/the screw...this car's idle is controlled by the ecu. adj'g the idle screw wont accomplish anythin other than 2 get u farther from ur real problem. if u did go 2 far w/ur port work, that will cause a prob. reset the ecu, make sure the tps is hooked up properly, make sure ur idle screw is back where it should b, and start over.Originally posted by artin:
tps = throttle position sensor
mess with the screww till you get your desired idle
<font size="2" face="Verdana, Arial">mess w/the screw? dont mess w/the screw...this car's idle is controlled by the ecu. adj'g the idle screw wont accomplish anythin other than 2 get u farther from ur real problem. if u did go 2 far w/ur port work, that will cause a prob. reset the ecu, make sure the tps is hooked up properly, make sure ur idle screw is back where it should b, and start over.Originally posted by UltegraSTI:
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by artin:
