......where should I stick them?
No, really.....not a joke.....I swear....
He had a tough time removing the nut that is welded to the control blade, but he got it with his dremel.Translation anyone?
If your talking about the rear camber bolts they replace the outer bolt on the upper control arm. You have to remove the existing bolt then grind or cut off the nut, best to do with a dremel tool and cut off wheel. then simply replace what you just removed with your new eccentric bolt and nut as per the instructions that should have accompanied your bolts....good luck......where should I stick them?
damn mike, I had a long day of work and it was late. Cut me some slack! jeez!Translation anyone?
