Leo has those on his two 2005 Spec Cars.only_in_a_domestic said:any one do brake ducting on a 05+ threw the fog lights??
Z63R said:That's a retail $385, not cost plus 10%...
Ted7rns said:Leo has those on his two 2005 Spec Cars.
I like this set up the best, best of both and no issues with rubbing.bri said:I did this cooling set up this weekend also, but I added my own twist, I made tabs similar to how Mysvtftoy did his but I raised the blades up higher like Jefe did except I used a longer bolt and a spacer. I also added a 3” hose that get air form the fog light cut outs and the directs the air to the blade.
I haven’t driven the car other then around to block to make sure noting rubs.
http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=214626tparker said:Does anyone have a link to get the blades?
Porsche fins and XP10s up front are working for me. I thought I was getting some fade the other day after about 25 minutes of going round and round, but I figure it to be the ABS kicking in while heading downhill going to threshold braking on a slightly slick surface.supersonicsvt said:...On the track, I had zero issues (I'm sure the XP10's didn't hurt either!) and could get into the ABS every time.
Not with an oil cooler and a power steering cooler in the way................getn2focus said:seems pretty simple.......:screwy:
