So, this winter, I plan on making some major changes to my car in the name of making it better to drive. As it is, my car was recently placed in H-Stock (most likely by oversight/mistake) at an event based on SCCA rules, and won by an extremely wide margin, even on all-season tires. I don't imagine the same mistake will continue to be made next year, and I'd like to build the car to fit a class as well as possible while still maintaining the goals I already have. My priority with this car is to build it to be as much fun (according to my personal taste) as possible in every situation I drive it in, then to be as competitive as possible when I do race it. Basically, what I "feel" the car "needs" to be fun to drive comes first, SCCA rukles come second. I'd rather lose in a car that I absolutely adore than win in a car that I'm not 100% fond of.
For reference, here is what the car has...
-H&R coilovers, stock strut mounts
-450 lb/in rear springs, 150x60mm, standard H&R front springs
-Polyurethane rear endlinks
-Polyurethane torque strut inserts
-SPC camber arms
-K|BDev. toe arms (heim jointed)
-2.5" exhaust, factory header
-Marcy intake
-Steeda Tri-Ax STS
-16x7.5 et20 wheels
-205/40-16 Kumho Ecsta AST
-Disconnected front swaybar
-Rubber front lip spoiler (from an Escalade)
And here is what I plan to do before now and the beginning of next season:
-FSWerks "Race Plates"
-H&R 514lb/in front springs, 100x60mm with helpers
-H&R 571lb/in rear springs, 100x60mm
-Rear droop limiters (if needed)
-Reconnected front bar with adjustable, heimed endlinks
-Polyurethane front and rear LCA bushings
-Crower 3/4 race cams
-Header
-Dyno tune
-3.5" aluminum intake with 3.5" MAF tube
-Dyno Tune
-Clutchmasters Stage I clutch
-Clutchmasters aluminum flywheel
-205/40-16 Falken Azenis RT615K tires on 16x7.5 et20
-300mm front rotor conversion with Centric slotted rotors and Stoptech pads.
My question is this: Where would this put my car for classification? I'd like to run Street Prepared, but I have a feeling that the heims in some of my suspension parts and the camber plates will move me to Street Mod. If that's the case, is there anything that I can/should change/add to my plans to better fit a specific class?
Please excuse my ignorance, I appreciate your time!
-SPC camber arms
-Marcy intake
-Steeda Tri-Ax STS
-16x7.5 et20 wheels
-Header
-Dyno tune
-Dyno Tune
