1 - 4 of 4 Posts
After installing two adjust. cam gears 4 weeks ago the cam belt is at the outer edge of the cam gear and is griding on the housing - ruining the belt. I tried a search but don't understand the adjustment. Could the tensioner be ruined from over tightening? It seems to be loose even after several attempts to tighten the belt. This has come up before but Im need a picture or instruct for the fix. Those in the know please help.
How did you tighten the tensioner? did cam gears come with instructions? If not then click here to go straight to the FocusHacks website instructions on how to intall cam gears. This should give you all the info you need to fix it. just look at the instructions and see if it is how you did the install.Goodluck......Russell
Discussion Starter · #3 ·
Thanks Russell I did not know this detail instruction was on site. This is not what we did to set the tension. Will give another try. Thanks for your help.
1 - 4 of 4 Posts
