1 - 12 of 12 Posts
i have a 02 focus with the zetec and the cover that covers up the cam gears can that be removed without doing any damage to the car , i know that in some cars that its hooked it the underside of the valve cover but i couldent tell if it was ot not and will it hurt anything not running the cam gear cover thanks in advance
i have my cover off and i have no problems. there are a few small bolts. i dont remember what they are. but most people have to break it to get it off. so if you want to put it back on one day i wouldnt take it off
I would suggest doimg it on a hot day or while the cover is hot so it's maleable and your able to bend it a little more. i got mine off w\ out cracking it just had to yank on it for a while.
I removed mine when installing the cam gear. We removed the motor mount during the process. I believe that one, possibly two (would have to check), studs block the cover or make it tough to remove. I know the cover came off real easy.
1 - 12 of 12 Posts
