1 - 2 of 2 Posts
I want to install a set of cams most likely stage 2. I want to know would it be worth fitting adjustable cam gears aswell. The who is the best for Cams
Thanks
Cam gears are always good to do at the same tme as cams. THey really help out if you have a dyno to tune them though. As far as what brand you want you should search to find which ones you want. I have the crowers which are high rpm power cam. The crane/ford racing give more mid range power/tourqe. Talk to any of the sponsors that carry cams and get them to help you out. [email protected],[email protected],[email protected] are all good.
1 - 2 of 2 Posts
